keesm schreef:We kunnen het avontuur weer aan: BaseCamp 4.4.4 Is Now Available
Zie: https://forums.garmin.com/showthread.ph ... -Available" onclick="window.open(this.href);return false;
Download: http://www8.garmin.com/support/download ... sp?id=4435" onclick="window.open(this.href);return false;
Verdere info:
This release does not support XP.
Installation of this version will overwrite your previous BaseCamp installation.
Here are the changes made in this version:
- Fixed several issues when using the Pan Tool and the <ALT> key to move route points
- Fixed autorouting issue where straight line segments were inserted after each waypoint
- Improved track to route behavior. Now supports preserving the shape of track sections that aren't near a road.
- Improved handling in situations where the computer is low on memory
- Changed displayed route times to take layovers into account
- Fixed issue with 'higher education' map symbols showing up as airports
- Fixed certain instances of route direction text where the text was 'turn left/right' instead of 'bear left/right'
- Fixed issue when recalculating a route via the context menu in the data list
- Fixed various issues sending data to memory cards
- Changed to automatically unlock BirdsEye for a device when sending the BirdsEye to a card in that device
- Fixed various issues with Adventure search
- Fixed issue sending ADM files to cards for marine devices
- Added the command line option /Disable3D to disable the 3D view in BaseCamp. This was added to prevent startup issues with misbehaving graphics drivers.
The non-English language version of the software will be available through the in-application software update check shortly.(heb de download gedaan en Basecamp wordt gewoon als Nl-versie geinstalleerd)
*4.4.3 as a version number was skipped to be in-line with the Mac version.
Garmin Basecamp 4.4.4 voor windows beschikbaar
Zie ook het draadje op het GPS forum: http://forum.gps.nl/viewtopic.php?f=109&t=44874
- Wehoo
Re: Garmin Basecamp 4.4.4 voor windows beschikbaar
Reeds geïnstalleerd zonder problemen.
Werner.
Werner.
- Hans Vaessen
Ter info:
Er zijn twee probleempjes met 4.4.4. ontdekt; beiden niet heel schokkend, maar toch:
a. zoeken op POI-categorie gaat niet goed: ook al zoek je op alleen chinese restaurants: alle POI's worden getoond. Oplossing: zoek via alt-ctrl-F
b. bij toevoegen van een viapunt wordt de route vernacheld. Dat doet zich voor als je werkt via het 'slepen' van de route als uitgelegd in http://youtu.be/Im2uWFRauX8" onclick="window.open(this.href);return false; . Oplossing: die methode in 4.4.4. dus even niet gebruiken maar in plaats daarvan 'ouderwets' met de invoegknop - dat gaat wel goed.
Beide bugs zijn inmiddels gemeld aan garmin - ik verwacht een spoedige 4.4.5...
goed bezig Hans!
+1
+1
Dag allemaal, vraagje is het probleem met Basecamp 4.4.4 al opgelost , vandaag kreeg ik melding voor update Basecamp 4.4.4 ,Kan ik beter nog wat wachten, of nu updaten.
Groeten Jean
Groeten Jean
- Hans Vaessen
Nee, je kunt zonder problemen updaten van 4.4.4. naar 4.4.4.
zonder gekheid: gewoon de laatste versie gebruiken. Als je al tegen een probleem aanloopt staat hierboven de oplossing.
Dank U Hans voor de Info
Groeten Jean
Groeten Jean
